Page 57 of 75
FirstFirst ... 7 47 55 56 57 58 59 67 ... LastLast
Results 1,681 to 1,710 of 2222
    Jan 2014
    Kazakhstan
    But this area is a statiс, then why encoder / sensor prefer to replace him by another / alien specimen - logical?
    Jan 2014
    Kazakhstan
    Originally Posted by LigH.de View Post
    What you call "future references" seems to me like a preference of weighted B frames (generating blends) over motion vectors. Now that is indeed a point to discuss with the developers. The reconstruction appears to have blends which don't exist in the original video.
    By the way, Derf's 1080p Y4M source is a lot more detailed than the ProRes file.
    ProRes format compact, and is preferred in modern home camera. Alternatives are not yet that I have not seen.
    But also has a longer playing time (the ProRes MOV only has the last 2 of 10 seconds from the Y4M), a download of 1483 MB.
    Complex 2 seconds have much to say / specify, and also for a fast encoding by reason the processor.
  3. DECEASED
    Jun 2009
    Heaven
    build 1.3+190-67ee212bbf78
  4. DECEASED
    Jun 2009
    Heaven
    build 1.3+198-1de67321275e
    # HG changeset patch
    # User Steve Borho <steve@borho.org>
    # Date 1410786013 -7200
    #      Mon Sep 15 15:00:13 2014 +0200
    # Node ID dd060bfda6e57f17aa7663de805db8d3a7ed7edc
    # Parent  dff0cd55b520620ef8a7a9b7f4a7c0861f26b351
    param: preset tuning changes
    1. disable SAO in superfast
    Recent changes have made --no-sao substantially faster than SAO, which has made ultrafast preset much much faster than superfast.
    By disabling SAO in superfast, it is now roughly half-way between ultrafast and veryfast again.
    2. Enable weighted prediction for B slices in slower, veryslow, and placebo
    Weighted prediction for B can sometimes be beneficial, so turn it on for slower encodes.
  5. DECEASED
    Jun 2009
    Heaven
    build 1.3+199-7c1aba99f40d
    Originally Posted by Aarthi Thirumalai
    rc: fixes for 2 pass + vbv to calculate frameSizePlanned accurately.
  6. DECEASED
    Jun 2009
    Heaven
    build 1.3+207-86686bd153db
    Originally Posted by Steve Borho
    frameencoder: fix VBV row resets when SAO is disabled
    When SAO is disabled, the row bitstream is generated as CTU analysis progresses.
    We must reset the row bitstream after a restart to avoid coding errors.
    The CAABAC state is already reset correctly when CTU col 0 is re-coded.
    Image Attached Images
    Jan 2014
    Kazakhstan
    Hi
    Now used lightweight r-frames 5 and b-frames 8 (placebo).
    One can observe as a fly printed / cloned on the tree (between a group of people), still is, the encoder prefers to replace static plots for the wrong/alien texture of the subsequent frames.
    I pause this theme for a month.
  8. DECEASED
    Jun 2009
    Heaven
    build 1.3+213-25dde1ffab66
    rc: improvements for cbr
  9. DECEASED
    Jun 2009
    Heaven
    build 1.3+219-4680ab4f92b8
    Originally Posted by Praveen Tiwari
    denoiseDct: align performance data while reporting speedup
  10. DECEASED
    Jun 2009
    Heaven
    build 1.3+226-c8f53398f8ce
    param: do not allow VBV without WPP
    VBV row restarts cannot function correctly without WPP (per-row CABAC starts)
  11. @El Heggunte, would be nice if you could actually provide a link to the quotes you do,..
  12. DECEASED
    Jun 2009
    Heaven
    https://bitbucket.org/multicoreware/x265/commits/all
    But I am pretty sure you already knew that.
  13. Yes, I knew that the chance that these quotes were either from the mailing list or the changelog was high. Still posting quotes without a reference to the source is a bad habit.
    Aug 2013
    Central Germany
    Additionally, only the description of this specific patch is quoted, not of all relevant patches in between. The value of information may be limited. But well, the content of the image is not much related either... good to have builds released now and then, I know I am a bit late sometimes. I'm usually waiting for a reason. Like a "merge with stable". Or just another week gone...
    x265 1.3+240-1c172c1822e4
    Aug 2013
    Central Germany
    Two more builds as "last week's results". There is a lot more parallelization going on. The last version (1.3+362) has different compiler warnings by GCC, depending on the variant...
    x265 1.3+331-b6d49505b179
    x265 1.3+362-4b7c473c3ef4
  16. No builds anymore by El Heggunte ?
    What happened ?
  17. DECEASED
    Jun 2009
    Heaven
    What happened ?
    I'm running out of energy -.-
    Also, the forces known as "Der Untergang Des Abendlandes" don't like to see pictures of pretty women u_u
  18. Originally Posted by El Heggunte View Post
    Maybe you could make builds, say, once a week ?
    Well, the thread is about x265 MinGW builds, the girls are-were just a plus. Perhaps you should not make it personal and try not to focus on that but on the builds because I'm quite sure there are more people missing the builds than the girls
    Aug 2013
    Central Germany
    Another "last week's result": x265 1.3+378-f26e81eb555a
  20. Originally Posted by LigH.de View Post
    Thanks!
    Keep it up
    Aug 2013
    Central Germany
    I'll do. Even if there are compiler warnings (which are usually harmless, some compilers assume too much about the source, appear almost paranoid about what might fail, even if the developers are certain it will be very improbable).
  22. Member
    Aug 2013
    Central Germany
    Another week of patches: x265 1.3+619-7eab67ffff81
  23. Member
    Aug 2013
    Central Germany
    Even for CPUs without AVX2 support (AMD Phenom-II X4), speed is clearly increasing again (just by general refactoring and removing superfluous calculations), even though in a low percentage only. But I would assume that the speedups for users of modern CPUs will be much more impressive, just counting the number of AVX2 patches in the last month.
  24. Originally Posted by Gravitator View Post
    It's been nearly a month and a half
    Any update on this "bug" ?
  25. Member
    Aug 2013
    Central Germany
    Another "weekly": x265 1.3+788-3a8f6f685436
  26. Member
    Jan 2014
    Kazakhstan
    Салам,
    The same in VP9 > doom9
    I look forward to when the video moguls will provide free video via donations - pay as much as you do not mind. Then piracy transformed into something new... And the internet / mobile providers agree to support this system (have their percentage of the tranche). The main thing is the convenience and accessibility.
  27. DECEASED
    Jun 2009
    Heaven
    build 1.3+855-31ed48cdbefe
    Originally posted by foxyshadis
    New build v1.3+855 with new option --deblock that works just like x264's. Now you can test --deblock -1 or -2 and see if that improves film noise. Now's your chance to play with it and see if any bugs are present before the final release. Should be pretty stable, lots of bugfixes have gone into it recently and 1.4 appears to be right around the corner! Speed and quality have both improved since 1.3.
  28. DECEASED
    Jun 2009
    Heaven
    build 1.4+5-eebb372eec89.7z 0_o 0_o 0_o
  29. Member vhelp's Avatar
    Mar 2001
    New York
    yeah, looking at the 90+ count, i would say that we have a ton of windows xp users using/testing x265. thanks for posting those builds, much appreciated!
  30. Originally Posted by vhelp View Post
    FYI LigH's builds are working fine on XP as well as El Heggunte ones
